Old 05-18-2015, 12:09 AM   #28 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Originally Posted by California98Civic View Post
The fuel pump tested normal.
Would a dirty strainer fail intermittently? Would injectors or their o-rings leak intermittently? After two or three rainy days in which normal function resumed, the problem has suddenly emerged agajn and with a vengeance. Return of the sun, warmth, and dry conditilns has meant a return of my fuel trim wackiness.
Part of the difficulty is knowing I cannot necessarily count on the sensors, meaning that the ECU might be cutting fuel based on false data from the MAP Sensor and/or the O2 sensor, right?
Bah! I gotta start testing stuff. Thanks all.
This sounds silly but what is your ground wire like (condition) on the intake???
Pressure Gradient Force
The Positive Side of the Number Line
The Following User Says Thank You to pgfpro For This Useful Post:
California98Civic (05-18-2015)
