Old 05-19-2015, 12:27 PM   #96 (permalink)
cowmeat
cowmeat's Avatar
Princess Carriage - '20 Ford Explorer Limited
Silver - '22 Ford Maverick Hybrid XLT w/tow pkg
Maverick Hybrids
90 day: 41.3 mpg (US)
If you find one for yours, here's the installation (which takes a total of ten minutes)
Items needed:
(2) 3" 90 degree shelf brackets
(6) screws with Phillips heads
(2) U-clips to attach the spoiler to the brackets
Phillips screwdriver
Small hole punch with Plastic handle
Blowtorch
Sharpie
Beer
Tape Measure
#1 - Measure the center of the spoiler, and mark the back side with a sharpie
#2 - Put the spoiler on the corner of any handy flat surface and bend it gently at the mark until it's at about a 15-20 degree bend (dry-fit until the correct angle)
#3 - Dry fit it where you want it on the car, then with the sharpie put two tiny marks below it where the centers of the brackets will sit behind it
#4 - Take the 90 degree brackets and bend them (I used a vise and a hammer) to the correct angle, dry fit them to make sure the spoiler will sit vertically
#5 - Mark with the sharpie where you need to screw the brackets into the lower bumper
#6 - Hold the pointed end of the hole punch in front of the blowtorch until it's red hot, then push the point through the plastic bumper where the holes are
#7 - Add the clips to the top holes of the brackets, then screw the brackets into the bottom of the bumper, and screw the spoiler into place
#8 - Stand back and admire your work while drinking the beer (this step is optional)
