Thanks for the info, Chaz! I guess I just got lucky using the template.
Goldenstate, I use the receiver hitch quite often. Need the spare also, as I don't have AAA or any other service. Does it really matter that much, I'm wondering. This truck is close to 6000lbs, and the weight of the plywood lid is around 90lbs. That is an added 1.5% of the total weight, but I guess every little bit helps.
