Originally Posted by serialk11r
Apparently bump starting is possible but the car really doesn't like it and lights up the dashboard, and I prefer to use the starter.
My Renault will do the same if you just let out the clutch while moving. In fact the ECU will shut off the engine all together and you have to key off and restart to reset it. However, it still bump starts fine with the double clutch method
