Making a run to Temple and back with Dark Aero hooked up tomorrow. This will be a first time run down that way with Dark Aero in tow. It's about a 2 hour run on some standard Texas two lane highways.
Been running around town with the trailer attached to git a better feel fer some different configurations fer the past week. Gonna give the 60lb sand ballast a try again with the new air spring and see if it will calm the rear end from bouncing a little more.
During a run to Dairy Queen last night, the skid plate got a work out and it did protect the tailcone from gitting ripped off when I backed up into a slanted berm. The only visible damage was some white paint was scraped off which meant I only had to repaint the bottom of the skid plate this time around.
