Old 05-22-2015, 09:45 AM   #53 (permalink)
cosmick
Experienced UAW Mechanic
First, Daox, if you're following this, should it be moved to where my RX-7 thread is?
Second, I got the early-'90s Jeep Cherokee upper steering shaft, then ordered a lower, but I'm going to run it inverted, since it has splines at both ends. I need the clearance at the upper end. I don't really need the u-joint on my lower end, the rag joint clears fine, but tossing the rag joint will improve feel and response. But I found a nicer lower at a local salvage yard, which is how I discovered I was inverting it.
Then on the right side, rather than dimpling the exhaust manifold with a hammer and an oxyacetylene torch I don't have, I think I can get that clearance with an aftermarket tubular upper control arm. As long as I use the versions that use a greaseable steel bearing instead of a poly bushing.
By itself this is around $50 plus shipping. But then add a new upper balljoint, that adds cost.
While online researching all this, I learned more than I could imagine. Like using a "tall" ball joint to improve the camber curve, but this requires getting the arm from UB Machine, they designed their arms for these joints. And these are basically iust '84 Chevrolet C10 upper ball joints.
So far, so good. Little extra cost, I'm game. That'll get me driving by July.
One arm, one joint. Then after the Cruise-In, as funds permit I can do the same on the left side, do tall lower joints from Proforged, and do police Caprice spindles with '89 Turbo Trans Am rotors, 12" from my current 10.5", plus the tall lower joints reduces bumpsteer in this case.
So for very little investment I get big improvements in cornering and braking, to go with the V8 power.
Lastly for today's update, I found a lower cost way to recalibrate the speedometer and shift points for my 2.73:1 axle gears, but that'll wait until after the Cruise-In. $90 all total for the recal with shipping both ways. Plus I'll have the top speed limiter raised to match the tires and horsepower. I found a sale on 225/60R16 tires, so that's what I'm putting on the rear, making my cruise RPM 1562 @ 65 MPH once I swap my 3.08s for my 2.73s.
This engine pulls 1610 @ 65 in fullsize pickups, so this is safe. 2.47s are rare, but I hope to try some.
