Old 05-24-2015, 02:24 AM   #89 (permalink)
cRiPpLe_rOoStEr
Originally Posted by aardvarcus View Post
Here in the states, I am used to seeing plug in heaters that plug into grid power. This would have the advantage of less added weight as you don’t need a battery, with the disadvantage of only being able to plug in when you have a plug.
The idea would be to use the same battery of the vehicle to provide power for those starting aids, just like a stock glowplug or grid-heater setup.
