Old 07-27-2008, 11:57 AM   #7 (permalink)
Raysp30
SaturnSl1 - '00 Saturn SL1
90 day: 40.21 mpg (US)
MyPickup - '96 Ford Ranger
CRX HF - '89 Honda CRX HF
90 day: 51.59 mpg (US)
Originally Posted by justpassntime View Post
You could use bedliner of some sort, sound deadening padding or dynamat. All of those require pulling the carpet out of the car with the exception of the bedliner. I used the cheap padding JC Whitney has under the carpet on my 73 Ranchero and used spray on bedliner in the bed. It worked really well.
Here's what I'm thinking. Tear off all the carpet, at least in the back under the hatch and put some of the carpet padding under everything.
For the wheel wells, I'm thinking I could spray some insulation foam in there. It wouldn't give me access to some of the wiring, but I figure if the electrical wires have lasted 20 years, they should be fine for another 10.
That seems like the cheapest way to do it. $25 for carpet padding and maybe $5 for insulation foam.
