"Plus" fitments, if done with forged aluminum wheels, reduce the weight of eavh wheel/tire assembly, which helps MPG, especially when accelerating, and also helps brake cooling. But it looks bad unless you add larger brakes, which is a net improvement in both performance and safety, but is a net loss of MPG.
