Originally Posted by RPM
Where I live the tire size must match one of the ones listed in the car documents, otherwise it will fail the annual safety inspection and be subject to a fine. Those 3 are the sizes I can use.
So use the OE junk to pass inspection, then run what you like the other 364 days every year. Not like the police can do anything more than make you go get re-inspected, for which you can fit the OE junk.
