Originally Posted by samwichse
You could always throw the 165/65 R14 re92 Potenza on there. It's pretty much THE eco-tire, although it turns about %5 more RPMs/mile than a 175/65/R14, I'd bet you'd still come out ahead on the MPG.
Obviously rim-width dependent, I think the widest rim it'll fit is 6"
Sam
As you increase wheel diameter, this often lets you add positive offset to the wheels. This may reduce turning radius if you don't clearance the suspension, but is worth looking into. For example, '82-'92 Camaros can only fit 8s in a 16" size, 17s can fit 9.5s, but 18s can fit 11s, all without sticking out from under the stock fenders.
