Originally Posted by Frank Lee
Instead of finishing what's there you could build an integral boattail.
I won't be going all out with this because I want to preserve the original look of the Centurion. But lengthening it say 12 inches would help out the aero profile a bit. I think the back of Centurion slopes a bit much and could be softened up to taper more gradually without sacrificing the overall look. So I may be up for this since I did have planned to do some work on the back in regards to the rear hatch. It may also be necessary to lengthen a little in order to get the rear wheel skirts to fit and look right anyways. A long tailed Centurion may not be a bad idea
Aeromods I have planned for sure are as follows:
#1. Front Window rake reduction similar to Centurion #3
#2. Full Belly Pan
#3. Side Mirror Delete like Centurion #1
#4. removable rear wheel skirts
#5. Grille Block
#6. Ride Height Reduction
#7. Shaved door handles
#8. Windshield wiper compartment
