Old 05-27-2015, 03:34 PM   #492 (permalink)
Arragonis
The PRC.
Originally Posted by hondo434 View Post
Back from Florida. Had removed magnets on way down. Put magnets on fuel line only for return trip. Terrible traffic and accidents up to Richmond, so I reset computer from Richmond to home. Smooth sailing, 30.1 mpg with average speed at 59.4.
This really doesn't prove or disprove anything.
Let me compare - my journey to work is uphill and I get typically 5-10 MPG less then when I go home again, downhill.
Lets say I think having a Unicorn horn on my car will make an instant MPG difference because of "magic". OK it's a theory.
If I strapped a unicorn horn (sustainably sourced natch) to my car's bonnet for the journey one way and then removed it for the journey back it means nothing.
If I spent a tank with it off, then a tank with it on, and then off again then maybe I'm starting to get something meaningful. More meaningful still would be a closed track or reproducable section of road where I could test the effect repeatedly - maybe 5 times without, 5 with, 5 without.
You've had the A-B-A testing description tapped here loads of times. Do that. Anything else is just wasted electrons.
You could put your travel / MPG log into your own thread though, that would be fine
The Following 4 Users Say Thank You to Arragonis For This Useful Post:
Frank Lee (05-27-2015), mcrews (05-27-2015), MetroMPG (05-28-2015), Piwoslaw (05-27-2015)
