Old 05-28-2015, 05:27 PM   #3 (permalink)
Joris
Volvo 360 - '85 Volvo 360
Peugeot - '01 Peugeot 306
Advanced timing is better for fuel economy, up to a point ofcourse. The combustion of the fuel and air mix happens at the best moment possible, instead of a little late or to early. This way you get the most energy out of every bang. With todays fuels you can easily advance your timing a bit on older cars.
Advancing your cam timing also helps, because that shifts the powerband lower on the rev range. Combine that with a little loose valve adjustment for some shorter duration and lower opening and it should be noticable.
