Old 05-28-2015, 07:52 PM   #23 (permalink)
Chrysler kid
5 pin sensor
Zippy - '96 Honda Civic Hx
90 day: 40.77 mpg (US)
Boring - '11 Ford Fusion Sel
90 day: 21.88 mpg (US)
Originally Posted by 2009Toyotoad View Post
Hmmm..... I thought that even the Aluminum blocks had steel cylinder liners? I believe my 2009 Toyota 1NZ-FE engine has the "spiney" type liners which twist lock into the Aluminum block. It would be or should be the steel liner which give account for a higher iron content during break in. The other difference is that Honda and Toyota both use a private patented micro-polishing process on liners, pistons, wrist pins, and cams and crank bearings, which GM does not use. I believe they have another process altogether.
Depends on the block, chevies are just all aluminum for the ls1, typically over 800hp they switch to an iron block
Hondas are sleeved blocks but I can't recall sleeve materials as I believe it was done primarily for cooling and not for strength so I'm guessing aluminum sleeves
0w8 would be too thin in the heat here.
Current: 1997 civic lx
Past: 1998hx/1996hx/1997lx/1997hx Cali/1997hx
OG lean burn member
My civic thread
