Old 05-29-2015, 06:12 AM   #6 (permalink)
Finehouse
In addition to what others have said, the transmission from an EX isn't ideal, either, as it's relatively short compared with a DX or HX transmission.
Another part of the project, or a separate project, that I had planned was to put in an HX transmission because of the higher gearing, but that's something for another time. What do you mean by relatively short?
Originally Posted by Gasoline Fumes View Post
Honda engines spin "backwards" compared to others. Using the Honda transmission won't work. A bigger and older engine might not be the right direction for economy either. A VW diesel engine and transmission might be a better fit in a Civic.
Backwards? You mean counterclockwise instead of clockwise, I'm guessing. Why is that?
Also, I chose the OM616 due to its extreme and rugged reliability, something that isn't there as much for the VW engines.
Originally Posted by markweatherill View Post
In the UK at least, the Civic was available with a diesel engine.
Can one of those engines be shipped to the USA?
