Originally Posted by redpoint5
You're going to have to crack it open and disconnect the battery. I've had to do the same to tablets before. Why people buy such junk is beyond me, but I don't see people running away from crApple any time soon.
It could still be failing hardware, so cycling the power may only be a temporary solution.
I only buy business-class laptops now because I keep them for 4 or 5 years. The consumer-class stuff usually falls apart just after the warranty is up. Consumer-class is fine as long as you budget to replace it every 2 years.
I disagree with this general statement. I bought a cheap acer laptop when i started college 6 years ago and it still works fine. Its a little slow now and is very particular about having the fan cleaned often, but still works fine.
