Old 07-27-2008, 04:38 PM   #92 (permalink)
jamesqf
Originally Posted by dcb View Post
Is yours a typical vehicle? Is this an instantaneous reading or a real one?
No, it's not typical: it's a Honda Insight :-) The readings are instantaneous, but I can hold them for miles if the conditions don't change.
But except for the lean-burn capability of the Insight engine, the same principles should apply to any car. All the instances I gave are from when I was running on gas only - I'm not using the hybrid system to give false impressions, in other words.
