Old 06-01-2015, 05:58 PM   #5 (permalink)
AndrzejM
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
I've build and installed few MPGuinos.
1. Is it hard to build? I wouldn't say that especially if you're using ARDuino as a platform. A bit more complicated is to build it using just the ATmega chip.
2. Is it hard to install? Sometimes it requires a bit of work to locate and run the cabling.
3. Is it better than ScanGauge? I would say it's different. It definitely doesn't give some additional info that you would get from SG. Like engine load, temps etc. But it gives plenty of info about how you drive.
The best in MPGuino is that you can set it up any way you want. You can use big or small LCD, put buttons or LCD anywhere you want. It needs of course more work than to plug and play SG, but it definitely gives more satisfaction.
That's my opinion.
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
The Following User Says Thank You to AndrzejM For This Useful Post:
wadesworld20 (01-13-2020)
