Old 06-02-2015, 08:39 PM   #2 (permalink)
apowers
apowers's Avatar
Sometimes my USB adapter does not respond. I keep trying a different port till it does. That might not be your problem.
I would not try troubleshooting at pack voltage. Maybe just use a 12 volt battery.
The first thing I would is if there is a short between motor negative and battery negative. That would be bad.
I hope that helps some.
Then maybe see what is working on it.
Alvin
