Old 06-02-2015, 10:19 PM   #5 (permalink)
apowers
apowers's Avatar
Yes continuity is what I should have said. Did you spin the motor at 12 volts using the controller? If so then it should be working.
Did you get the RTD working?
I saw on the other forum someone had built some of the controllers for sale. They had said that if the mosfets are shorted on that the contactors would not close. I never knew this. That seems like a good feature.
Alvin
The Following User Says Thank You to apowers For This Useful Post:
Lectrik (06-08-2015)
