Old 06-02-2015, 10:34 PM   #1 (permalink)
Whitetail Ranger
NEW TIRES and bug sheild delete on 99 ranger
So its been a month or 2 but i finally got new tires. I went from those worn out Good Year Wrangler Authority all terrain tires to good year trail marks all season tires. They run quiet and smooth but i now keep the tires at recommended pressure for the truck after what happened to my old tires. These tires are the same size but due to there construction they seem to be skinnier than the A/Ts and have less aggressive tread as i would expect from these. The tire's sidewalls on these are more flush to the rim than the A/Ts as the A/Ts were like fitting a wider tire on the stock rim. I decided to post this as a new thread as i had made comments about my truck on my old thread towards the end and everyone stopped responding to it. Anyway i will try to post pics. of the changes to my truck. Also i still can achieve 24 mpg at certain times with tires at stock pressures and found that my air box intake mod doesn't necessarily increase my mpg since i set it up back to stock. Slight difference in throttle position but no real change in power or mpg.
