Old 06-03-2015, 08:15 PM   #12 (permalink)
oil pan 4
The new one I am working on:
5500w 18,000BTU/Hr
Has to go in a 1.5 inch pipe.
Need to find a 1.5 out side diameter to 1 or 3/4 inch bushing and a double female coupler in the same size. Just some time before it get cold again.
I may wire in a control circuit using the existing cold start switch to cycle the pump and heating element on and off. I should only need that if it works faster than expected.
