Old 06-03-2015, 11:24 PM   #22 (permalink)
Sneakybassturd69
If you can find them and they are not stupid expensive, go for it.
Wheel bearing if properly setup really don't create much friction to start with. Plus wheel bearings are operated at relatively low speed, usually turning less than 900rpms at 60mph. But that all depends on tire size and actual speed.
I prolly won't do it then, I read all the propaganda from the ceramic companies lol and I want to take it to the MAX! so I was a little more easily influenced by some of there bs, but this is why I am running this by the ecomodder community to point out some of the holes I can't see my self . Thanks for the knowledge
