Old 06-04-2015, 04:47 PM   #10 (permalink)
RPM
RPM's Avatar
JF - '97 Honda Civic 1.5i LS VTEC (EK3)
90 day: 59.68 mpg (US)
Originally Posted by Chrysler kid View Post
You are correct sir, the factory springs on there are progressive so the more they compress the harder they get. The rears were the same way, I had to guess which springs out of the box were the fronts as they are only about an inch difference in height
Cool! It's a better design than the one used by Eibach and other manufacturers. Those tend to produce a lot of noise when the softer portion of the spring extends and then collapses all at once, e.g. when passing through a pothole.
