Old 06-04-2015, 05:12 PM   #11 (permalink)
Chrysler kid
5 pin sensor
Zippy - '96 Honda Civic Hx
90 day: 40.77 mpg (US)
Boring - '11 Ford Fusion Sel
90 day: 21.88 mpg (US)
Originally Posted by RPM View Post
Cool! It's a better design than the one used by Eibach and other manufacturers. Those tend to produce a lot of noise when the softer portion of the spring extends and then collapses all at once, e.g. when passing through a pothole.
I didn't do too much research but saw the eibach kit was around $250 for a 2 inch drop, and the tein were $140 shipped for a 1.7 drop. Most reviews said the tein springs were a waste of money because they lowered the car very little; but being my daily driver and the fact I'm 30 years old I wanted something soft. The s tech springs were double the spring rate of the factory springs but don't seem to ride any differently
I should also mention the bump stops on the struts seemed to have seen some abuse so I am certain they were sagging lower than the we're intended to
It also helps that I am running the factory 14 inch wheels with the factory size tires, pictures I have seen of a 15inch rim and a low profile tire make these springs look almost like stock
Current: 1997 civic lx
Past: 1998hx/1996hx/1997lx/1997hx Cali/1997hx
OG lean burn member
My civic thread
