Old 07-27-2008, 10:14 PM   #49 (permalink)
cfg83
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
blackjackel -
Originally Posted by blackjackel View Post
Alright, I've decided to go ahead and fabricate myself some wheel skirts, I've decided I don't want to do any drilling ANYWHERE, meaning the skirt cage will be clamped to my wheel well.
I need a bendable material that will allow me to bend it so I can clamp it to the inside of the wheel whell and I need to find some sort of really strong clamps to hold the cage on there...
This is the "mini clamp" option I was talking about :
It's a sliding window security lock. It can lock onto material that has a width up to 1/4". If the "key screw" causes interference with the tire, you can replace it with a grub screw. If you use the grub screw, the maximum clearance requirement is about 5/16". However, you need enough clearance for an L-shaped hex-wrench to screw in the grub screw.
If there is still an interference problem, there are other manufacturers of these window security locks that may have smaller dimensions.
CarloSW2
American Solar Energy Society
