Old 07-27-2008, 11:43 PM   #12 (permalink)
Big Dave
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
What I've found:
If you can live with a tonneau, get one. I had a flat tonneau and it was worth 1.5 MPG. Better yet, a fastback bed cover.
To help change the nut behind the wheel, install a pyrometer and a digital tach. For Ford (I-H) 7.3s the magic numbers are 2000 RPM and 600 degrees F EGT. The numbers should be similar on a 12V Cummins.
Since you are 4x2 maybe you can economically regear. I dropped from 3.73s to 3.08 gears. That gained me 3 MPG. But you have an auto and those gears may wreck your auto. I get away with it because I have a hand-shaker. Don't sweat the towing/hauling with 3.08s. My 7.3 tows Bobcats, macinery, and five tons of building materials just fine. No self-respecting Cummins jockey will admit the school bus motor is better than a 12V Cummins at low RPM.
A 4x2 can also be practically slammed, resulting in a 4 or 5 percent reduction in frontal area.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
