Originally Posted by Piotrsko
Nope regular ferraz shawmat 400v 300 amp. I believe I r2 is around 1000 amps for 10 seconds which is shorter than temperature coefficient on the cables I have
Do you have pictures? Model numbers? I am not using 'regular' fuses because the ones I found have a much lower DC rating than they do for AC.
The DC rated fuses cost more and are harder to source
It would be GREAT to use a regular fuse!
