Old 06-06-2015, 06:19 PM   #1 (permalink)
Daox
Added an air dam to the '99 Metro
This afternoon I made up an air dam for the Metro.
Here is what I started with. Its actually closer to 9" of clearance, but with holding the tape measure and the camera you can't tell.
I used lawn edging from the local big box store. I think this whole coil was $5.
I also picked up a bunch of L-brackets at the store. These were about $.70 cents each.
Using existing holes in the bumper (and drilling one here or there), I put some bolts through it to hold it in place.
Here is the finished product.
Still plenty of ground clearance, even for winter I think.
I have only driven the car once since the mod. Its not a familiar route, but it seems to coast a tiny bit better. I maintained speed down a hill where I normally loose speed slowly.
ID:	17895   Click image for larger version
ID:	17896   Click image for larger version
ID:	17897   Click image for larger version
ID:	17898   Click image for larger version
ID:	17900   Click image for larger version
ID:	17901   Click image for larger version
The Following 15 Users Say Thank You to Daox For This Useful Post:
aerohead (06-08-2015), AndrzejM (06-07-2015), BabyDiesel (06-06-2015), BamZipPow (06-06-2015), dirtydave (06-06-2015), elhigh (06-08-2015), Hyperaboutmpg (06-23-2015), j12piprius (06-06-2015), mcrews (06-07-2015), MetroMPG (06-06-2015), mpg_numbers_guy (04-12-2018), oldtamiyaphile (06-06-2015), ThePrudentNinja (07-06-2015), whatmaycome14 (07-15-2015), Xist (06-10-2015)
