Old 06-07-2015, 03:34 PM   #123 (permalink)
Baltothewolf
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
Originally Posted by Trinost View Post
Q1:
So is the Sylvania 9003 headlight bulbs really a good upgrade or is there a better one out now in 2015?
Q2:
Also how did you buff the headlights? I have read about wet sandpaper and/or using products what did you use cowmeat? Those headlights look amazing!
Q3
I don't see the write up for the kill switch from Balto with pics can you link?
Q4
New to forums how to I contact a the person Doax for the really cool three-button shift knob he made me from his 3D printer? I'm not sure I would want a logo on mine since I drive a G1 red insight.
This is my first post I was just searching random google sites and found this and decided to join. Purchased mine in March from someone trying to run it into the ground. Slowly replacing basic parts. I purchased the 2000-06 Honda insight regenerative braking circuit and Honda insight 2000-06 Clutch interrupt circuit/ for 5-speed models. I believe I read that you mailed your Throttle Smoothing Circuit also for 5-speed models to someone else since wasn't really helping? I decided to ask before purchasing that if was really worth purchasing.
Here you go:DIY Injector kill switch install. - Insight Central: Honda Insight Forum
I buff my headlights with some hard water stain remover. Don't use sandpaper, unless you are gonna do it right and spray clear coat on them.
Don't get the throttle Smoothing Circuit. It sucks.
The Following User Says Thank You to Baltothewolf For This Useful Post:
Trinost (06-23-2015)
