Old 06-07-2015, 04:42 PM   #61 (permalink)
AndrzejM
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
Originally Posted by Bataleon View Post
True. That's a pity! What if I removed the serpentine belt completely and replaced the battery with a deep cycle battery?
I jacked up my car during lunch and tried spinning the wheels to see if there was any brake drag. The two front wheels are very stiff and only travel about 1/5 of a turn, even with a good push (the car gear was in neutral).
The back wheels are slightly better, although the back left wheel spins freely and then suddenly slows down, almost as if the brake pad is rubbing at a certain point.
How freely should the front and back wheels spin? Is brake drag easy to adjust?
I was off for few days so I couldn't check how it's with my Polo. I'll do that and post the results soon.
Removing alternator is a good thing for FE, but I'm driving my cars mostly on a long distances - for shorter trips I'm using my bicycle. So that's not for me.
But first your car has to be in a sound condition. That thing what you wrote about your rear wheel can give you an extra 1+l/100km or even more. You should check that. Definitely.
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
