OK good. So it's definitely not a fault from the NAND gates. The signal is making it to U6, but isn't making it to U7. Yes, I think U6 is bad. If you get a replacement, I would get the hcpl-4506 instead of hcpl-4504. That's a newer part that has a better current transfer ratio, and works a lot better.
