Old 06-10-2015, 03:51 AM   #55 (permalink)
Theitguy
its simply not displaying anything (I.E. the led display is left blank) im thinking that my button resistor values may be different to what you had. im using a freetronics LCD shield with resistor values as below. how do you have the buttons set up? where you have "analogin > 120" is this your voltage value??
Code:
int readAnalogButtonArray()  //this function converts the value from the button voltage divider to a useful value
**int analogIn = analogRead(0);
**if(analogIn > 120)
****if(analogIn > 380)
******if(analogIn > 640)
********if(analogIn > 900)
**********return 4;
********return 3;
******return 2;
****return 1;
**return 0;
