Old 06-10-2015, 10:07 AM   #95 (permalink)
Daox
Originally Posted by samwichse View Post
Pierburg Cooland Pumps CWA 50 $75 - DIY Electric Car Forums
How about a cheapo all-in-one unit? Pierburg CWA 50 specs:
Voltage: 8.5 to 16 volts
Current at 12.5v : 6.5 amps
Free flow capacity: 30 liters per minute.
Capacity with 20ft head, 8.7 psi, 0.6 bar: 24 liters per minute
1/2 inch barbed ports.
How much flow rate do you need? 24L/min is a bit more than 1 gallon every 10 seconds.
That looks like a nice little pump. The problem is I have absolutely no idea what kind of flow rate I really need. Its a lot of guess work and a lot of basing things off the OEM setup at this point.
