Originally Posted by Old Tele man
There are TWO ways to build-up "heat", heavy load and long duration...what's your driving scenario?
If you run beyond 18:1 air/fuel ratio, the combustion temperatures drop drastically. So does engine torque output. If you can balance your load with a lean combustion mix, you are good to go.
