Old 06-11-2015, 12:37 PM   #102 (permalink)
Daox
The other night I started working on the key for the pulley. I chopped it out of some 3/8" plate I had kicking around. It still needs to be trimmed up a bit, but I ran out of grinding wheels, so that'll get finished up another night.
Here are the pics:
As mentioned, I cut this out of 3/8" plate. Its supposed to be 1/4" x 3/16" x 1-1/2", so it took some grinding. I just went at it with an angle grinder to get it to shape. Trial fit, then grind some more, trial fit, grind, rinse repeat. Then, I drilled two 1/8" holes. These aren't the right size for the #6 tapped holes, but its what I had and its close enough.
With the holes drilled, I could tap them.
And here we have it assembled. The key fits great and does its job. The pulley actually fits a bit looser than I'd like on the shaft. I must not have double checked my dimensions before printing. It will still probably work.
Here is everything bolted up to the motor. As I mentioned, the key still needs to be ground down in the middle so the nut fits on all the way. But, it all goes together quite well. I'm happy with it.
ID:	17938   Click image for larger version
ID:	17939   Click image for larger version
ID:	17940   Click image for larger version
ID:	17941   Click image for larger version
