Definitely worth implementing to save about 3hp in 1 l motor [used old Hot Rod mag data, probably way high from your comments] which can be put to good use. Check with moroso co., they are the leaders. Durability of electric motor is the real issue, and re engineering of coolant and electrical system. Good fortune with your project. TD
