Originally Posted by dhanson865
Neil I'm not sure if your 2015 has the 3.x KW charger or the 6.x KW charger.
The 2012 PDF applies to the 3.x KW only no matter the year. If you have the 6.x KW you'd want to check
http://avt.inel.gov/pdf/fsev/SteadyS...on2015Leaf.pdf for the additional data.
2005 Prius 195/65/15 Energy Saver A/S (corrects speedometer by ~2.2%)
2012 Leaf tires TBD, have 16" rims, probably switching to 15' rims
