h4 led buy a 20 / 30W bulb a few months ago.
6000k color was, I did not like. it is blue.
a color of 4300K I like more. It is white.
the bulb was 3 chips xml2 believes.
two light up in low light.
three light up in high light.
the difference between short and long is too little. If you regulate the beacon for low light. high light has insufficient height. to put a larger amount of long light note to the sides. sees no more distance.
the car has a piece of metal which covers the bulb that comes. the bike if you have the piece of metal. dont keeps light out in some addresses.
Car lighthouse bulb led car dazzles. It gives a portion of the light upward. on the bike does not dazzle.
with halogen bulb light is balanced.
with LED bulb there are very bright areas. less bright areas. and dark or not unlit areas. this can be seen in the pictures that got a few meters from the wall or garage door.
LED bulb is the gift for my father to his motorcycle enduro. that only use for the day.
LED bulbs are not suitable for halogen headlights.
if you want led. you have to change the lighthouse by led.
Car:
Motorcycle:
Scooter:
E-Bike:
