Originally Posted by Daox
Can't help you with the tuning, but I'm following with interest.
You should also start a garage entry and fuel log for the car! It looks like we have one guy with a BRZ in there and he is getting 26 mpg...
Yea I should probably start tracking the fuel again, but like I mentioned at some point I'm doing weird blends of E85 and gas to increase my fuel's octane rating, and I burn through gas VERY slowly so it's going to be extremely hard to keep track of since I don't even get full tanks much, I just fill up halfway when I see cheap stations. I'll be doing a 35 mile one way commute in 2 months which should give more data points though.
According to the mpg indicator though, in "city" conditions I'm getting high 20s and on the freeway a little under 40 average. The mpg indicator uses MAF/load (g/rev) readings plus target AFR to calculate mpg which is not very accurate though, especially when using an E20-25 blend like I am.
