Old 07-28-2008, 09:35 AM   #28 (permalink)
MazdaMatt
2k2Prot5 - '02 Mazda Protege5
90 day: 33.82 mpg (US)
Originally Posted by BlackDeuceCoupe View Post
Why?
Because it can take heat energy and transform it to kinetic energy without anything more than a change of state. Once it leaves your exhaust, it cools and condenses on the nearest pretty little flower to keep the hippie's garden growing.
BDC, you seem like a reasonably intellegent dude and you yourself proclaimed your ultimate status as researcher king of the world in a different thread. Go read up on it and you'll understand why this engine isn't totally bogus. It may not yet have been engineered to perfection, but the idea is quite sound and aluminum-hat-free.
Good point about the 2-stroke. I wonder if a TBI 2-stroke could simply choose when to spray water or gas based on cyl wall temps. Engine is too cold, run as normal. Reach operating temp and do 1 water cyclefor every 9 gas cycles, then, 2/8, then 3/7 till a temperature equalibrium is met... interesting.
