Originally Posted by GreenHornet
...............(1) I have looked into several options and most likely I will go with an all Aluminum dual core unit that are used for Go Karts. They can be found on Ebay for $100. ....
(2)....Along with this I will do away with the mechanical water pump and install the electric water pump I have (EWP80).......
(3)... Kubota Z482 .......
(1)i looked these up. very nice and should be perfect. here is one on a bike:
![](http://i6.photobucket.com/albums/y232/hutbooker/rivi11/PCDV0005.jpg)
(2)you already have this? prices for them are off the chart.
(3)there are so many projects using this engine. really like the ones on the Enfields.
2003 S-10, 2.2L, 5 speed, ext cab long bed.
So far: DRL delete, remove bed mount toolbox.
