How, exactly, does witnessing the bike idling 750 RPM faster than normal (remember, it's not adjustable, the ECU controls idle speed) for the first 5 minutes after installing the Pulstar plug (with no other changes to the bike), and immediately noticing that the rough idle the bike's experienced since 05 Jun 2011 (at 797.4 miles, I keep very detailed logs) was now completely gone, and this after I'd previously torn down the bike from the gas tank to the fuel injector, from the air cleaner to the intake valve in trying to track down the source of the rough idle... how exactly is that "Unicorn"?
Or perhaps you're referring to my going to a hotter coil, and eventually to a custom-built corona discharge system? That's because this bike is a rolling test platform, and I'll be experimenting with alternative fuels and lean lambda, so I'm going to need a hot spark to light the fire.
