Old 06-14-2015, 06:56 AM   #63 (permalink)
Bataleon
Bataleon's Avatar
Cool
Originally Posted by AndrzejM View Post
I was off for few days so I couldn't check how it's with my Polo. I'll do that and post the results soon.
Removing alternator is a good thing for FE, but I'm driving my cars mostly on a long distances - for shorter trips I'm using my bicycle. So that's not for me.
But first your car has to be in a sound condition. That thing what you wrote about your rear wheel can give you an extra 1+l/100km or even more. You should check that. Definitely.
My Polo was serviced last week (synthetic oil + filter change, brake fluid change, timing/cam belt changed) so things are running a bit smoother.
I still don't understand how you (and other ecomodders here) manage to get such amazing fuel economy. I drove 3.5km (half downhill) with a warm engine and my consumption was 7.7l per 100km. That was with me coasting in-gear and out of gear where I could, depending on how I needed to control my speed.
Do you think EOC would help? Or am I losing efficiency somewhere else?
Originally Posted by renault_megane_dci View Post
The least good practice is to dismantle the caliper, clean it up (no reason to open the brake circuit) and make sure the caliper slides easily (assuming it is a single piston setup as is often the case, it has a sliding counterpart)
For drums it's a little trickier.
They do get clogged up so can be cleaned but they also usually have a freeplay suppression setup that does the exact opposite of what you do want (as a non braking ecomodder enthusiast) and I wouldn't tell you they're easy to remove ...
Thing you can do also is clean up the side of the disks with a file because they usually rust where a step is formed from the braking.
Awesome, thanks for the tips. I had my brakes checked and cleaned during last week's service so hopefully the drag has been reduced. I'll jack up the car later today and see how freely they spin.
