Old 06-15-2015, 12:25 AM   #2 (permalink)
oil pan 4
1, yes you are increasing heat load.
2, depends on how over computerized everything is. Likely its just the cold coils of aluminum and the water that makes up the mass of the evap coil and ducting that blow cool air for a short time after the A/C is switched off.
3, the tests I remember reading about said that A/C decreases fuel mileage by around 10%.
