Old 06-15-2015, 01:43 AM   #24 (permalink)
oil pan 4
Does this 7.3 not have a turbocharger?
If you are not going to install a turbo you are throwing away a 10% to 20% fuel economy increase.
Decreasing the final drive ratio on a non turbo diesel is going to increase exhaust gas temperature as you try to work the engine harder at lower RPM. You will just end up blowing more heat out the exhaust.
