Old 06-15-2015, 06:47 PM   #27 (permalink)
freebeard
Have you looked for a drawing of the door bracket disassembled? I predict a C-channel facing downward.
If you had a clear plastic truncated boattail over the mirror, it would only need a window in the inner face to allow you to see into it (and the truncation to see out). A good approximation would be a baloney-cut cone, down to an 'eyebrow'. It could be an extension of your deepen bullet.
Only a driver-side mirror? If you invert the stalk so it slants down instead of up, can you still see into the mirror?
