Old 06-16-2015, 05:55 AM   #46 (permalink)
GreenHornet
GreenHornet's Avatar
Here are the general specs of the Frigidaire AC unit that I am going to get. One thing to note is the depth at 15 1/4. The Centurions have a shelf right behind the seats of roughly 9" depth and 13" height. This shelf acts as the rear bulkhead for the seats to back up to and also houses the Triumph Spitfire fuel cell. So if used unmodified the unit will work but will protrude into the hatch storage space 6 inches. This is not necessarily a game changer but if I can modify it a little bit to take advantage of the length of the shelf this would be more beneficial for me I think.
GENERAL SPECIFICATIONS
Warranty: 1 Year Full/5 Year Sealed System
Refrigerant: R410a
Window Height (Min.): 13"
Window Width Min. (Max.): 23" - 36"
Product Weight (lbs): 42
Shipping Weight (lbs): 47
Power Type: Electric
Installation Type: Window Mounted
Collection: Frigidaire
AC SPECIFICATIONS
Fan Speeds (Cool): 2
Fan Speed (Fan): 2
Low Voltage Start-Up: Yes
Energy Saver: Yes
Filter Check: Yes
Clean Air Ionizer: No
Remote Control: Full Function
Air CFM (High): 124
Motor RPM (High): 1,380
Motor RPM (Low): 1,268
Air Direction Control: 4-Way
Noise Level dB (High): 57.0
Noise Level dB (Low): 53.0
Fresh Air: No
Exhaust Vent: No
Vents Closed: Yes
Filter Access: Side Slide-Out
Slide-Out Chassis: No
Cabinet Louvers: Yes
Window Mounting Kit: Pleated Quick Mount
Charge (ozs): 11.1
PERFORMANCE
BTU (Cool): 5,000
Dehumidification (Pints/Hour): 1.1
Cool Area (Sq. Ft.): 150
Energy Efficiency Ratio: 11.2
Performance Certification: AHAM
EXTERIOR SPECIFICATIONS
Height: 12"
Width: 16"
Depth: 15-1/4"
ELECTRICAL SPECIFICATIONS
Voltage Rating: 115V, 60Hz
Amps (Cool): 3.9
Watts (Cool): 446
Horsepower (Cool): 0.60
Power Cord Length: 6' (6-1/2')
Plug Type: LCDI 5-15P
CERTIFICATIONS & APPROVALS
ENERGY STARŪ Certified: Yes
Safety Certification: UL/CUL (SA11087
