Old 06-16-2015, 03:17 PM   #49 (permalink)
samwichse
Thalmaturge
CHONK - '18 Honda Clarity
Also: If you can get an AC with a linear compressor, the start-up wattage issue goes away. As their compressed volume is essentially continuously variable, they can start and run with a constant draw and a variable output (ie, the compressor strokes will be shorter until the startup surge is overcome).
Unfortunately, I'm not seeing anything but split units with that tech in them ATM.
Sam
